360 F1, Gear Whine in third gear
Old 08-03-2011, 05:34 PM   #1
Ferrari Life Posts: 5
Default 360 F1, Gear Whine in third gear
I have recently purchased a 2000 F1 360 Modena. I have already had problems with the heat exchanger and a transmission relay. The car makes quite a bit of gear whine in 3rd gear and the used car dealer's mechanic says that this is normal. I would like to confirm whether other owners also have this noise or if it is something that I should get them to check. Thanks for any input.
mark_suyama is offline   Reply With Quote
Old 08-03-2011, 05:52 PM   #2
Ferrari Life Posts: 6,600
w hy would you get them to check it if they say it is normal? I would go somewhere else. I don't have a 360 but i can't imagine excessive trans noise in a single gear is normal. Shortly a 360 owner will respond i'm sure. Welcome to f-life and how about a pic of your car?
Everything you know is wrong
Old 08-04-2011, 08:31 AM   #3
Ferrari Life Posts: 1,419
I'm no F-wrench, but my 360 does NOT make noise like that.
Curiously, how would a used-car dealer know what is normal in a 360?
If you didn't have a PPI done before purchase, I strongly suggest one now (i.e. ASAP).
Old 08-04-2011, 04:15 PM   #4
rebuild, sorry.
Old 08-04-2011, 04:51 PM   #5
I did have the PPI done and none of the issues that I have experienced since were noted. I had the car in to the shop to replace the relay for the F1 transmission when I mentioned to them about the gear whine. I have already posted some pix but here is one again.
Old 08-05-2011, 04:54 AM   #6
nice looking car. i would seriously get it to a very experienced ferrari mechanic. even if you have to transport it some distance. trannys aren't cheap.
Old 08-14-2011, 11:34 AM   #7
What I thought was gear whine turned out to be a problem with the ground on the new stereo system.
Old 08-14-2011, 12:36 PM   #8
champagne612's Avatar
Ferrari Life Posts: 4,631
Good news enjoy!
Bad news is the "mechanic" who said the sound was normal.
Ferrari Life » Ferrari Forum » Ferrari Owners » Modern V8s: 360, F430 » 360 F1, Gear Whine in third gear
