| Owner Elite Member Join Date: Jun 2008 Location: SoCal
Ferrari Life Posts: 61
I am considering Titanium wheel bolts for my 360 with 5 spoke 430 rims. Thoughts?
| | #2 | |
Ferrari Life Posts: 2,406
My thought is that while clearly in the "way cool" category, you probably don't want them. Ti is strong but much softer then steel so the bolts would be much more delicate so they would be easily damaged which would lead to major damage to your car if not caught in time. Weight that against the very very small (as in unmeasureable) performance gain they would give you and I don't see them as worth the money or risk....but they sound very cool. | |
Ferrari Life Posts: 5,047
+1 : Stick with steel. Ti may be cool but not a good idea and in this case may be dangerous. Somethings are best designed as is.
Thanks for the input. The bolts are being offered on ferrarichat.com in the ads section
Ferrari Life Posts: 7
The Ti bolts are originally equipped on Scuds, 16M's, and 360CS's. Have not heard of any of those applications shearing bolts, and can not find any reason against using them. The only time I might be weary would be if put onto a circut using slicks, perhaps. GL with your decision either way!
| | #6 | |
Ferrari Life Posts: 6,600
am i right in believing the advantage is to slightly reduce unsprung weight? how much would you really get and how much value?
I would expect the weight to be only a factor in F1. Not sure one gains much in unsprung weight for street cars or light racing use. Guide to the Galaxy: Don't Panic Rik -- LAH ! Current: 1990 Mondial T Cabriolet : Red/Tan 1995 456 GT 2+2 : Roso Metalizzato [Fer 311/C] & Tan |
So here's the latest. I bought the Scud wheel bolts. I have heard all of your points of view, for and against. I thank you all for your input. I figured I give them a try as I like the look and think they will look great with the CF or black wheel caps. This is still another decission to make. My question now is the torque. Do I torque these the same as the 360 steel wheel bolts?
| | #10 | |
As I said earlier, Ti is much softer than steel and generally requires special care such as a specific lubricant or torque settings. Also confirm the bolts have the same thread engagement depth as on the Scud. | |
| | #11 |
Mike; Thanks for the information. |
| | #12 |
| QUESTION: I am assuming there are different 'models'/degrees of Ti as there are steel in composition. Wouldn't that be a factor also, or are these 'pure' Ti and not an alloy?
| | #13 |
| They would be an alloy. There are lots of alloys, Ti6Al4V is the more common but there are lot of other good choices.
