Instrument Panel Illumination
Old 11-18-2010, 05:31 AM   #1
Ferrari Life Posts: 1,419
Default Instrument Panel Illumination
When turning on the parking lights using the switch in the center console, the external parking lights illuminate normally. However, the green "P" warning light on the instrument cluster does not.
I called Ricambi to order a replacement bulb. They do not have one listed and are unsure what type is required.
Anyone here know? If so, is it a major job to replace it??
Old 11-18-2010, 06:17 AM   #2
Default Responsive and Relevant
Below is a response I got from Josh.
As usual, this site provided timely, relevant, and accurate info from people that have real-world experience with these cars.
SF,
Killer
I looked at the parts diagram in ricambi and they don't show the bulbs seperately. I do have a 360 here right now so i slid under the dash to look...
You have to remove the cluster and then remove the rear cover to access all of that. Then you'll have to match the bulb up with one at the local part store.
The good news is you only need to remove the four stainless allen screws on the front face and it'll slide out.
Be sure to drop the steering column with the adjustment lever before sliding it out and use a towel so you don't scratch the column up.
__________________
Exotic Car Specialties
www.ECSofVirginia.com
201 Davis Dr. Suite LL
Sterling, VA 20164
Ferrari Life » Ferrari Forum » Ferrari Owners » Modern V8s: 360, F430 » Instrument Panel Illumination
