Battery charging / conditioning
Old 10-21-2010, 07:15 AM   #21
Ferrari Life Posts: 65
Just to let people know, I just ordered a CTEK XS3600 from Amazon for £43.
Hopefully this should keep the battery in tip top condition from now on
chesterfield is offline   Reply With Quote
Old 10-21-2010, 09:59 AM   #22
Ferrari Life Posts: 12,792
Well done
Boxer
Old 10-24-2010, 06:17 PM   #23
Magnum6464's Avatar
Ferrari Life Posts: 1,695
Now you can rest at ease.
Mario
1990 348 TS (87284)
Magnum6464 is offline   Reply With Quote
Old 10-24-2010, 07:36 PM   #24
Neonzapper's Avatar
Ferrari Life Posts: 974
That's the one used by the Ferrari specialists in my neighborhood
_________________________
1983 Euro 308 GTBi QV red/black s/n 44151
Neonzapper is offline   Reply With Quote
Old 05-20-2011, 08:15 PM   #25
Ferrari Life Posts: 79
Would any one know of a portable battery tender? I don't have an electric socket in my car park as it is communal. So i am looking for a battery that can supply electricity to the the tender. I was told that the solar ones don't work well. Any ideas or experiences would be appreciated.
PrancingHorse70 is offline   Reply With Quote
Old 09-01-2011, 07:08 AM   #26
Hi. Found a socket n finally got my ctek Mxs 5.0 battery conditioner. Question is where should I set the battery tender? Should I fix it directly on the battery itself (ie the front of the passenger seat) or the compartment behind the back of the passenger seat. I've heard people do it either way and wonder if there is a correct way to go about it. And if one way was safer for the car n its computers. Much appreciate the insights.
Old 09-01-2011, 07:09 AM   #27
Hi. Found a socket n I finally got my ctek Mxs 5.0 battery conditioner. Question is where should I set the battery tender? Should I fix it directly on the battery itself (ie the front of the passenger seat) or the compartment behind the back of the passenger seat. I've heard people do it either way and wonder if there is a correct way to go about it. And if one way was safer for the car n its computers. Much appreciate the insights.
Old 09-11-2011, 12:21 PM   #28
Just bought a Battery Tender Plus for my Porsche 993 TT a couple of days ago at Amazon. It was on sale for less than 50 bucks; not a bad deal. I hope to get an F430 before too long (till then have to get by with the 911TT).
Nathan is offline   Reply With Quote
Old 09-11-2011, 02:14 PM   #29
Jimmy Chen Shiba DDS's Avatar
Ferrari Life Posts: 3,549
Name: Jimmy Chen Shiba
Welcome to FL, Nathan. A fine car you have. w/ smiles Jimmy
Old 01-02-2012, 09:26 AM   #30
Barry's Avatar
Ferrari Life Posts: 3,256
Guys
I'm in need of a couple of decent battery conditioners. About to purchase a CTEK Multi XS3.6 - seems to be the replacement model for the CTEK XS3600.
Anything better I should be buying? They'll be used one the Ferraris and Ducatis.
Some details below.
Barry
CTEK Multi XS3.6 12V 4 stage Smart Battery Charger
The MXS 3.6 is a proven and reliable charger and is the new version of the award winning XS3600. It offers important features such as desulphation, maintenance charging and cold mode for optimised charging during cold winter days.
It is also suitable for charging demanding AGM batteries (i.e. Optima). It is the ideal charger for those looking for quality and simple connect and forget charging. The MXS 3.6 is a fully automatic 4-step charger that charges 12V batteries from 7–75 Ah and is suitable for maintenance charging up to 120Ah. The MXS 3.6 is IP 65 classified (splash and dust proof) and delivers selectable 0.8A or 3.6A. It is designed to protect vehicle electronics and is non-sparking-, reverse polarity protected and short-circuit proof. The MXS 3.6 is delivered with a 5-year warranty.
Auto: Fully automatic for optimal charging
12V: For all lead-acid batteries
Fully Charged Battery / Maintenance Charging
COLD/AGM: Charging in cold conditions and AGM batteries
Model number 1052
Volt 12V
Rated Voltage AC 220–240VAC, 50–60Hz
Charging voltage SMALL, NORMAL: 14.4V, COLD/AGM: 14.7V
Min battery voltage 2.0V
Charging current 3,6A max
Current, mains 0.65A rms (at full charging current)
Back current drain <1Ah/month
Ripple <4%
Ambient temperature -20°C to +50°C, output power is reduced automatically at high temperatures
Charger type 4-step, fully automatic charging cycle
Battery types All types of 12V lead-acid batteries (WET, MF, Ca/Ca, AGM and GEL)
Battery capacity 7–75Ah up to 120Ah for maintenance
Dimensions 165 x 61 x 38mm (L x W x H)
Insulation class IP65
Weight 0.5kg
RRP £70.00
Accessories available for this product:*
CTEK Lighter Charging Lead,
This accessory allows you to charge your battery through the cigarette lighter socket instead of having to go under the bonnet to connect up the charger, ideal if your battery is located in an awkward position.
CTEK Standard Attachment Lead ,
The lead is designed to be left permanently attached to the battery via the clamps so that when charging is required you can just plug in the corresponding plug on the charger, switch on and leave until the battery is charged. As a result it will save you the hassle of connecting up the crocodile clips that come with charger each time you use it.
Barry
Old 01-02-2012, 09:37 AM   #31
Guys
I have a pair of them now. Work great.
Boxer
Old 01-02-2012, 10:01 AM   #32
Barry's Avatar
Cool. Thanks.
Barry
Ferrari Life » Ferrari Forum » Ferrari Owners » Modern V8s: 360, F430 » Battery charging / conditioning
