06' F430 Flashing Gear issue?
Old 07-23-2010, 06:03 PM   #1
Ferrari Life Posts: 5
Default 06' F430 Flashing Gear issue?
This is a repeating problem that surfaced today on my '06 f430 with 27k miles.
when shifting into 4th gear, the gear indicator on the dash flashed 4, instead of it becoming solid, it kept flashing. Then it was ok to shift it to fifth and so-on.
However, when in 4th and its flashing, if you shifted down.. it drops directly to neutral. once in neutral, you could not put it back into gear until you were at the rolling speed, nearly stopped.
So.. cannot shift down above 3rd.. ok to shift up. Flashing gear indicator on 4. All of this started happening in "sport" mode. However, it is repeatable in all modes.
Any ideas? Out of warranty now.. so anything you know will help tremendously!
*If it matters, I am only owner.
iamodogg is offline   Reply With Quote
Old 07-23-2010, 06:56 PM   #2
Ferrari Life Posts: 477
First, kudos on getting this thing up to 27k! I'm not sure the exact cause of this problem, multiple issues with the 430 F1 system have been reported though and locking out of gear until the car comes to a stop is a safety function of the system.
I suspect one of the solenoids for 4th gear are acting up and creating your issue though.
Exotic Car Specialties
201 Davis Dr. Suite L
Sterling, VA 20164
703.421.5356
Old 07-24-2010, 04:57 AM   #3
Ferrari Life Posts: 70
When was the last time the f1 fluid was flushed and the actuator centered/serviced?
T.C.F.B. is offline   Reply With Quote
Old 07-24-2010, 01:58 PM   #4
Thx for the replies. I believe I had the F1 serviced just before warranty ended.. December?
So my best and only bet is to bring it in? This might seem like a ridiculous questions, so bare with me.. Do these cars hook up to code type diagnosis machines?
Old 07-24-2010, 07:09 PM   #5
Yes, you will need to bring the car to a shop equipped with the computer(SD3) to test the F1 system.
In this case the diag computer uses either a manual or self-test "procedure" where the components are activated one by one and either the auto test gets interrupted when a component doesn't respond appropriately or the Tech sees a flaw in the data which will indicate the component that is failing.
Sterling, VA 20164
703.421.5356
Ferrari Life » Ferrari Forum » Ferrari Owners » Modern V8s: 360, F430 » 06' F430 Flashing Gear issue?
