360 F1 - Can't find neutral
Old 09-26-2009, 08:18 AM   #1
Barry's Avatar
Ferrari Life Posts: 3,948
Default 360 F1 - Can't find neutral
Hi all,
Went out for a drive today, no problems, but left the 360 in 1st gear after I parked it on the drive. Few hours later I go to take it out again and cannot find neutral. Digital gear indicator keeps reading "1". No amount of pulling the 2 paddles towards me will find neutral. Equally I can't select reverse no matter how many times I pull back on the reverse "T" beside the hand brake.
Can anyone help - or suggest anything I can do????
Barry.
Barry is online now   Reply With Quote
Old 09-26-2009, 12:46 PM   #2
Ferrari Life Posts: 53
Default 360
will she let you start her in gear?and are you pointing the right way?sounds like you may have confused the brain thingy!i'd try to start in the position it is in and worry about finding neautral as you get going,does it have some sort of relay,that may have stuck on?sorry if this is not helpful more used to older cars.
woodyz is offline   Reply With Quote
Old 09-26-2009, 07:59 PM   #3
David Lee's Avatar
Ferrari Life Posts: 301
Well Barry it could be a lot of things the rubber stand under the engine could be wore out and the engine is not sitting on the car right, or your nightmare of owning a F1 gearbox have finally come true and you have a F1 pump problem is it a big problem you ask? YES it can be verrry costly for a replacement, try to switch the battery of for 15 mins and than turn it back on, start the engine don't touch anything for ten mins and let the pc re program it self then try the gears Chaz said that once see if that works, best you ask GCALO he can help you with that he is an expert on 360's and F1 gear box.
good luck!
David Lee is offline   Reply With Quote
Old 09-27-2009, 12:04 AM   #4
Ferrari Life Posts: 14,905
good luck!
+1, first thing I would try is killing the battery for 10 minutes and then turning it back on.
If this does not work, suggest you call the dealer for advise (one I PM'ed you should be happy to help).
Boxer
Current: F40, F50, 430 Scuderia
Past: 612 Scaglietti, 360 Modena, 360 Challenge, 550, 575, 365BB, 512BB, 456 GT, F355 GTS, 365 GTB/4 Daytona, 308 GTB
Old 09-27-2009, 02:38 AM   #5
Barry's Avatar
Gents,
Good news is that late last night (after I had switched the battery off and back on again) it found neutral. Have no idea what happened. I just got back in, did the usual, foot on brake and pulled the 2 paddles and on the 4th/5th try it went back into neutral.
Been out for a short spin this morning, everything appears fine, gear selection no problem (though I am making sure I park in neutral!).
So, big question now is - do I just pretend it never happened (the easy option ) or should I do something about it?????
Barry.
Old 09-27-2009, 03:38 AM   #6
Jimmy Chen Shiba DDS's Avatar
Ferrari Life Posts: 4,381
Name: Jimmy Chen Shiba
Good for you Barry, and of course you should do something about it,...by taking her out for more workouts. w/ smiles Jimmy
Old 09-27-2009, 09:15 AM   #7
Barry's Avatar
Thanks Jimmy, that's the kind of remedial advice I was hoping somebody would suggest
Old 09-27-2009, 12:16 PM   #8
JazzyO's Avatar
Ferrari Life Posts: 5,161
Jimmy is spot-on as usual.
Onno
JazzyO is offline   Reply With Quote
Old 09-27-2009, 04:01 PM   #9
David Lee's Avatar
Well excuse me then.
anyway good to hear it worked.
Old 09-27-2009, 04:07 PM   #10
Awwwwhh...David. Recovery is fast ? Maybe, you're treating your car way too "nervoseum" (to be self interpreted, whatever way one likes) ? Sorry, had to say it, beacusr your 355 is way too immaculate. w/ smiles Jimmy
Old 09-27-2009, 06:12 PM   #11
David Lee's Avatar
Well Jimmy, when someone is jumping around asking for help on FL, you would think they would be more appreicative when their problem is all sorted out, how wrong was i! no wonder is been so quiet here lately.
Old 09-27-2009, 11:14 PM   #12
Don't worry, Daivd. We all luv ya here. w/ smiles Jimmy
Old 09-28-2009, 01:22 AM   #13
Barry's Avatar
Hi David and everyone - don't get me wrong - I'm very appreciative for everyone's input. So much so that I called the dealer this morning to ask him about it. He confirmed your comments about the pump, and also asked me if I can hear it priming when I open the car door (which I can). So his thoughts were that it could be the relay/fuse. His advice was to replace the relay at the next service (which will be pretty soon), so that's the plan of action for the moment.
Thanks to all for your help.
Barry.
Old 09-30-2009, 04:39 AM   #14
Pressing hard on the brake pedal will usually resolve this problem.
jjsaustin is offline   Reply With Quote
Old 04-06-2012, 07:01 PM   #15
Ferrari Life Posts: 10
Barry, I experienced a similar problem, left the 360 for 1hr, pressed hard on the brake peddle, no further issue. Did you reach a conclusion?
Chris H is offline   Reply With Quote
Old 04-06-2012, 08:33 PM   #16
Ferrari Life Posts: 7,473
Chris- Welcome to Ferrari Life. That happened about 2 1/2 years ago and apparently Barry got her fixed.
Old 04-06-2012, 08:37 PM   #17
Ferrari Life Posts: 1,149
The thread is 3 years old but you are right, usually pressing very hard on the brake pedal works. The brake vacuum check valves in the 360 often leak down so there is no vacuum left for the power brakes. When that happens very high pedal pressure is required to make contact on the switch telling the computer the brakes are on so it will select neutral in the starting process.
Old 04-06-2012, 10:33 PM   #18
Thanks for the replies. Got my F360 Spider three weeks ago and this was one of those little quirks that is of interest and one which caught me out!
Old 04-07-2012, 07:29 AM   #19
Shane's Avatar
Ferrari Life Posts: 117
Me too Chris......I have been reading every thread in the 360/430 Forum lately. Thanks for the explanation Brian.....that makes sense.
Hows the weather over there Barry....? Happy Easter on the Emerald Isle....
Present: 1999 360 Modena 116113
Past: 1986 GTS 64263
Shane is offline   Reply With Quote
Old 04-07-2012, 03:14 PM   #20
Barry's Avatar
Dry, bright and warm. But I spent the day prepping a camper van for a trip....
Well before I went to see Leinster make their way into the European Heineken Cup Semi Final.
Barry
Ferrari's: 360 Modena, 308 GT4
DD's: LR Discovery, RR Sport, BMW R1200GS Adv.
Ferrari Life » Ferrari Forum » Ferrari Owners » Modern V8s: 360, F430 » 360 F1 - Can't find neutral
