550 (and I think 456 too) Window problems
Old 02-12-2009, 12:23 AM   #1
Ferrari Life Posts: 77
Default 550 (and I think 456 too) Window problems
Hi All
I think it is a common problem on 550's and 456's, that over time the driver and passenger window glass 'drops' a little inside its mountings or whatever, meaning that the door is never fully sealed against wind noise etc when fully wound up. It becomes really noising at 140mph !
Is it possible to take off the door panel and fix this myself, considering I am not much of a mechanic, or is it best left to a professional?
if it is possible, any advice?
Alex
relkeel is offline   Reply With Quote
Old 02-12-2009, 03:27 AM   #2
Ferrari Life Posts: 12,792
Originally Posted by relkeel View Post
Hi All
Alex
It is definitely a common problem on both. I tried to sort it myself once on the 456 GT. Effort was not successful and I ended up taking it to a pro.
Boxer
Old 02-12-2009, 10:57 AM   #3
Ferrari Life Posts: 3,613
From what I understand it is a quite involved process and expensive to fix. I have heard $5K-$7K!
There was a posting somewhere about a shop in Florida that has it worked out.
I'll see if I can find that post and info.
Ok try this:
The shop is called Formula 1 Imports and Exotics located in Naples, Florida.
Tel. (239) 430 2206 Jason is the contact and Erik is the technician.
Old 02-12-2009, 07:07 PM   #4
Check with Rik Granucci.
He's the resident 456 expert.
Old 02-12-2009, 09:26 PM   #5
Ok try this:
Above is for a permenent fix. Your local shop should be able to realign the window which will work for 6-12 months before the problem re-emerges.
Boxer
Old 02-13-2009, 07:34 AM   #6
JazzyO's Avatar
Ferrari Life Posts: 4,289
A very common problem on the 550. My specialist has corrected my windows twice in the last 18 months, last time 15 months ago. It's a 10 minute job and he has done it for free on both occassions. I have no need for a $5k solution.
Onno
Old 02-13-2009, 09:27 AM   #7
Ferrari Life Posts: 5,047
+1
Permanent: NO.
There is a wheel/pulley inside the front portion of the window that makes the glass slide fwd/backward even after the fix, given time. I have some info on the fix.
My 456 had the official Ferrari window treatment which if done on one's own cost in the near $8/for both windows. But that wheel wears after time due to more use.
That is why, in my research, I've seen the driver's side always be the problem the most, RHD vs LHD it is on the driver's side. Passenger's side as in mine is NOT a problem.
I will try to post, some of the pictures, hijacked from 'another site' sorry, it's on the web now and privacy aside, well, tough...open territory.
I'll bet even after your fix, if you put one palm on the inside of the glass and the other palm on the outside of the glass and press palms together with glass between them you can manually move that glass fwd/backward in the up position on the troubled window, while on the 'good/better' window it has less play.
The 'fix' requires taking off the inner panel and replacing the wheel in the front, upper portion of the glass channel and that will make for a tight seal.
HOWEVER, check the B-pillar for loose or poorly done stripping too as that can cause problems.
rik
Old 02-13-2009, 09:43 AM   #8
Ouch!
I thought only Ford had these problems!
Old 02-13-2009, 11:28 PM   #9
Ouch!
No, it was a major issue on the 456 GT when new. Not as common on 550s or 456M GTs. No problem builing a car that will do 180 mph, but getting a window to seal properly, that was a major issue. Goes back to Enzo philosophy, I sell engines.... you get the body for free (which in many cases was fair market value).
Boxer
Old 02-15-2009, 11:49 PM   #10
Onno
I like the sound of that. So can I do this myself, or better still left to the experts?
My only work I have been able to do on the 550 myself was snipping the seatbelt warning sensor. Best thing I ever did!
Old 02-16-2009, 09:45 PM   #11
Per my personal experience ----experts
Boxer
Old 05-01-2009, 02:24 PM   #12
agp22's Avatar
Ferrari Life Posts: 364
got rid of this stuff by changing the whole mechanism, about 1.000 euro
Now the car is silent inside
agp22 is offline   Reply With Quote
Old 05-01-2009, 11:02 PM   #13
JazzyO's Avatar
Sounds great. Could you elaborate a little more on what was done? Who did the work? I'd be interested to have this done next time my window goes out of kilter.
Onno
Old 05-02-2009, 06:54 AM   #14
agp22's Avatar
This is the mechanism that was replaced. The job was done at the dealership, the unit cost about 500Euro plus labor plus VAT, altogether about 1k.
Old 05-02-2009, 08:26 AM   #15
JazzyO's Avatar
So did you replace the normal mechanism with a new Ferrari one, or is it a new system (as in new solution) ?
Onno
Old 05-02-2009, 09:04 AM   #16
agp22's Avatar
it's a replacement Ferrari unit. the other one had some barely perceptible play, but enough to prevent adequate sealing.
Old 05-02-2009, 09:38 AM   #17
agp22's Avatar
This is what's on the box
Old 05-02-2009, 10:04 AM   #18
Looks like a smart way to go for a permanent fix.
Old 05-02-2009, 11:14 AM   #19
212Export's Avatar
Ferrari Life Posts: 2,288
Hello agp22, how are you doing ?! Great to have you back after quiet some time!
Old 05-03-2009, 01:40 AM   #20
agp22's Avatar
Hi 212. OK Thanks.
Ferrari Life » Ferrari Forum » Ferrari Owners » Modern V12s: 456, 550, 575, 599, 612 » 550 (and I think 456 too) Window problems
