599 6-1 Headers Manifolds - Ferrari Life
post #1 of 14 Old 03-13-2017, 05:15 AM Thread Starter
Ferrari Life Posts: 153
Hello guys,
today I have finally found an owner of 599 fiorano that will give his black Fiorano for take the dimensions and available space in order that I can do a good design of the 6-1 headers manifold for this car, including CAT.
Will be an expensive investment because for accept, I told him that the work will be by do by the Ferrari official Dealer and I will pay him also the annual service, an obviously the 3D laser scanner service, if will be not problems, work will be to the first week of april.
I'm very confident about the result because, after my experience on the 575 that have exactly same layout of CATs and lambdas layout, I know well how they work ....
I remember you that 599 GTO have not same lamdas layout of fiorano, 4 lambdas instead of 8, then GTO headers can't fit in Fiorano without ECU modifications, my intention is to make a system like 550-575 that will run without ECu modifications.
Best at all
Contact info: info@fiammenghiengineering.it
post #2 of 14 Old 03-13-2017, 01:01 PM
Ferrari Life Posts: 11,736
Fabio- Sounds exciting. A bunch of guys on the other site have been talking about 6-1 headers, including the fact you may be making a set.
post #3 of 14 Old 03-17-2017, 02:36 PM Thread Starter
Hello Terry,
after the experience that i done on the 575 6- headers developing i think that the developing of the same headers for the 599 will be a little bit easy ....
Yesterday i found one non official work shop that have two 599 disassembled with engine out of car!
They will permit me to make a scanning, by means of laser scanner, in order to make a 3d CAD model ...
Work scheduled for 28 of march.
Kindly
Fabio
post #4 of 14 Old 03-23-2017, 08:05 PM
Fabio- Sounds like perfect timing. Look forward to the result.
post #5 of 14 Old 03-30-2017, 08:14 AM Thread Starter
Hello Guys,
two days ago i went to an independent workshop (220 km to me) that had two 599 under working, one with the engine removed and one assembled, by means of 3D laser scanner we took models of:
- engine compartment without engine
- engine
- part of engine compartment with installed engine, for steering shaft position
- car lower side, in CAT area
- back muffler
Now I can design new headers like those i did for 550-575, rearrange my actual project of the cat bypass pipe, and make a design of sport mufflers.
Best at all of you.
Fabio
post #6 of 14 Old 04-28-2017, 09:43 AM Thread Starter
Hello Guys,
today i received the cad models of the 599, as per the followings pictures.
Now my 6-1 headers system project for the F 599 can go on
Best at all
Fabio
post #7 of 14 Old 04-28-2017, 10:14 AM
Fabio- Looks good and there is definitely a market for 599 owner who want their 599s to sound like GTOs.
post #8 of 14 Old 04-29-2017, 02:47 PM
Ferrari Life Posts: 224
Originally Posted by Fiammenghi Engineering View Post
Hello Guys,
- engine
- back muffler
https://www.youtube.com/watch?v=GTMIydO0Afc
Best at all of you.
Fabio
Ciao Fabio,
What 3-D scanning hardware (make/model, etc.) and software did you use? Is it the same 3D scanning equipment you used for your 575M manifolds or newer equipment?
Saluti,
Gianni
1997 Ferrari 550 Maranello; 1999 Ferrari 456M GT; 1996 Buick Riviera; 2008 Bentley GT; 2010 Lotus Evora.
Past cars: 1965 Corvette Stingray Roadster; 1974 Corvette Stingray.
Gianni is offline
post #9 of 14 Old 05-02-2017, 01:35 AM Thread Starter
Originally Posted by Gianni View Post
Ciao Fabio,
Saluti,
Gianni
Ciao Gianni,
the company that i called for the scanning service have Creaform (from Canada), they send me stp files and i use Solidworkks for design my products.
For design my 575 manifolds I not used acanner, for dimensions I used old methods, meter, caliber, after that i designed on CAD and before make the first prototype i removed original headers from my car and took on her last dimensions for make the equipment that now I use for manufacture.
Kindly
Fabio
post #10 of 14 Old 05-02-2017, 01:36 AM Thread Starter
Hi Terry,
i hope to do a good work ...
Best
Fabio
post #11 of 14 Old 05-09-2017, 06:54 AM Thread Starter
Hello friends of FLife,
the basic design of the headers system is completed ...
I like it!
Best regards at all
post #12 of 14 Old 05-09-2017, 07:05 AM
Fabio- Looks like it is time to start bending tubing. Have you found anybody to be your Guinea Pig?
post #13 of 14 Old 05-09-2017, 07:13 AM Thread Starter
Terry,
no, I will make by means of cut and weld of single bends and pieces of pipe, because is necessary around 2 diameter between two consequential bends, but in the headers the bends are more more near, then if i make by bending pipe after is necessary to cut and weld ........
post #14 of 14 Old 05-09-2017, 07:37 PM
Fabio- I can see the weld lines on your drawing.
