456mGTA electrical issues
Old 12-17-2011, 07:28 PM   #1
Ferrari Life Posts: 21
Default 456mGTA electrical issues
Hi everyone.
I unfortunately let my 456's battery get a little flat so I've charged it again and there seems to be plenty of life....secondary electrics work fine, however she won't turn over. All I get is a loud clicking resonating thru the sound system. Also, the ignition cuts in and out when I press the brake peddle. The clicking has happened before and seems to indicate insufficient charge but comes right after the battery is charged some more. Currently the battery has had about 72 hours on the charger and still she won't start.
Any suggestions?
DavetheChemist is offline   Reply With Quote
Old 12-17-2011, 07:31 PM   #2
a1exander's Avatar
Ferrari Life Posts: 768
Possible dead cell by the sound of things.
Have you a hydrometer to check the battery with? If not a test meter to see what voltage the battery is at whilst turning the key?
Is the battery "bubbling" whilst under charge?
a1exander is offline   Reply With Quote
Old 12-17-2011, 07:47 PM   #3
Dave- Those symptoms indicate a bad battery, like Peter said. I never give a battery a second chance. They are just not that expensive. If you swap it and it still will not start, then it is time for some more extensive diagnostics.
One thing you might check before swapping, though, is to make sure the ground strap is making good contact.
Old 12-17-2011, 08:42 PM   #4
Thanks guys. I'll pull the battery out and put it on a proper charger and see how things go tomorrow. I'll let you know.
Thanks heaps for the prompt replies
Old 12-17-2011, 10:02 PM   #5
Well.....battery is out and on the charger. It was making a very light bubbling sound on the trickle charger so I'm thinking I've let it cycle up and down too many times. Might have to keep the new battery on the trickle charger all the time as I'm only putting on a couple of hundred km per month.
I'll let you know how I get on tomorrow.....
Second thought.......who designs the secondary 'bits' on these cars? I'm always amazed that you cannot simply disconnect the battery, unhook a stay or two and lift it out. You always have to disassemble half the engine bay!!
Old 12-17-2011, 10:52 PM   #6
a1exander's Avatar
A sadist and the cars are bought by masochists.
Old 12-18-2011, 11:53 AM   #7
Dave- If you have a tendency to let the battery run down, get an absorbed glass mat (AGM) battery for a replacement. They can be deep discharged dozens of times with no adverse affects. Plus there is no danger of leakage.
Old 12-21-2011, 02:39 PM   #8
Yup......battery is stuffed. New sealed gel battery on order......I hate living at the end of the world....none in NZ - one on order....ETA: 6 weeks!!! Grrrrrrrr
Old 12-21-2011, 02:56 PM   #9
Ferrari Life Posts: 859
Battery on a 456 is far easier the get in and out than on many modern cars. It can easily be done in under a minute.
The worst I ever experienced was a Citroen SM. Removal of right front fender is step one. On our Mercedes disassembly of the interior is required. In many BMW's the battery is located under the electric rear seat. The electrical function is required to be operational to access the battery.
It is not a tractor. If you want the utmost in durability, ease of access and easy servicing I suggest John Deere. If on the other hand you want something that drives a little better some compromises need to be made.
Old 12-21-2011, 03:01 PM   #10
Ferrari Life Posts: 5,047
Mondial Ts are no fun front wheel needs removal.
Old 12-21-2011, 03:09 PM   #11
A friend's Porsche, can't recall the model, required the removal of a rear wheel to access the battery housing......car architects sure have a neat sense of humour!!
