Ferrari Life Posts: 737
This is a topic that has been beaten to death in various places and various threads. But what about putting the differences all in one place in a comparison table? The following table is a start, and if people who are knowledgeable about either or both models will contribute their knowledge, I'll update the table as we go. Presently, the table could really use some help in the body and interior sections (not that the other sections should be considered complete!) And if anyone (Brian?) knows the answers to these points, I'd like to update/correct the table: 1. What material is used for the valves, and is it the same for both the intake & exhaust? 2. The WSM's for the 550 and 575 indicate the valve guides are a "copper alloy" for both engines, however I thought a SiBr guide was used in the 550, followed by a cast iron guide in the 575? '99 550, Rosso Corsa / Nero, S/N:114654, Assy: 31836, Engine: 52084 High mileage, low compression, and missing on a few cylinders.....just like my cars. |
John- Cannot really see the chart easily on my Blackberry, but the 575M has sintered steel valve guides and the 550 has bronze. The 550 also has titanium connecting rods, which broke in the racing versions, so they and the 575 use stronger steel connecting rods. If you look in the parts catalogs, I think the 550, 575, and early 612 use the same steel valves. The Superamerica uses shorter valves because of a different valve seat angle.
| | #3 | |
About the rods, are you saying they were abandoned for the production 550 in favor of steel? Here again, the WSM for the 550 states they're Ti, and the 575's are steel. I'm beginning to wonder how much of the WSM is a work of fiction...... '99 550, Rosso Corsa / Nero, S/N:114654, Assy: 31836, Engine: 52084 High mileage, low compression, and missing on a few cylinders.....just like my cars. | |
| Owner Elite Member Join Date: Aug 2011 Location: France
Ferrari Life Posts: 42
John, for the 550 coolant radiator, wasn't there a change, with early models having a drain tap at the bottom, which could be easily broken off, and a later version with the drain repositioned to a "safer" place? Nigel |
| | #5 | |
Maybe someone with an early 550 can comment? '99 550, Rosso Corsa / Nero, S/N:114654, Assy: 31836, Engine: 52084 High mileage, low compression, and missing on a few cylinders.....just like my cars. | |
John, My 550 is from 11/97. I raised the point, as the radiator was changed in 2004 and I was told that the tap on the orignal radiator had been broken off or been damaged causing a leak and that the new radiator has the drain tap in a different, less exposed position. The parts list however shows no change in part numbers. Nigel |
| | #7 | |
| Owner Join Date: Aug 2011 Location: Belgium
Ferrari Life Posts: 50
John- On the titanium connecting rods, they were only changed on the racing 550s. The production 550s retained them throughout the run. Iam pretty sure the 575 had sintered steel valve guides, which were also recommended as replacements for the 456 and 550 if the bronze guides wore excessively. Cannot access the parts catalogs and tech bulletins to confirm until tomorrow night. The early 575s also had a unique thermostat housing with an extra water temperature sensor. This was changed during production for the 456/456M housing with no sensor. Also, the front suspension and wheel bearings were a different design on the 575 with no stub axles and reduced unsprung weight. The ABS sensor wires pass through the space where the stub axle was on the 550. The banjo fittings on the 575 transaxle were also much heavier than those on the 550. The fuel cooling ECU and hardware were eliminated on the 575 and one other ECU was also eliminated, but I cannot remember which one without reference to a parts catalog. The 550 actually had more ECUs than the 575. The brakes were identically sized except for one larger set of pistons on rear 575 brake calipers. 575M wheels were lighter weight than the replacement 550 aluminum wheels. Will add some more when I do not have to do it from memory and can reference your chart. Taz Terry Phillips Present: 575M 135171 Past: Dino 246 GT 02984, 365 GTB/4 14009, 308 GTS 25125 Every day I look around, and if nobody is shooting at me, it is a pretty good day. |
| Owner Join Date: May 2002 Location: New Jersey
Ferrari Life Posts: 1,257
Man, this is a great thread for 550 dreamers like myself. So here's a random, and possibly sacrilegious, question... Is it possible to bolt a 550 front bumper onto a 575? ie, is a straight bolt on affair, or would the bumper have to be modified. |
| | #10 | |||||
Bret, I think a 550 bumper could be mounted to the 575, because the reverse has already been done. At least one 550 owner bolted a 575 bumper onto his car because the 550 bumper hangs so low, and the winglets are always being damaged. I think he had to replace the 550 mounting brackets with 575, but in the end it was accomplished. '99 550, Rosso Corsa / Nero, S/N:114654, Assy: 31836, Engine: 52084 High mileage, low compression, and missing on a few cylinders.....just like my cars. | |||||
| | #11 | |
We'll see how things go in my 308 rebuild and with a bunch of outside factors (housing, jobs, etc.), but I could easily see a 550 or 575 as my next Fcar. It really is the best fit for my use case, and they're just so darn good looking. | |
| | #12 |
Here's an update to the table. Hope we can continue to get good participation ![]() I'm posting it as a jpg so it's visible to all, but obviously it's an Excel spreadsheet. I can attach that if people prefer it that way. The print in the jpg is pretty small..... '99 550, Rosso Corsa / Nero, S/N:114654, Assy: 31836, Engine: 52084 High mileage, low compression, and missing on a few cylinders.....just like my cars. |
| | #13 |
John- Here is the technical bulletin confirming the 575M valve guides and the recommended replacement guides for the 456/456M (and 550, not reflected in the parts catalog because of few 550 problems) and 575M were sintered steel, part numbers 188630 and 188631. Note that these guides were not fitted originally to the 456/456M, but are the recommended replacements because of wear issues on the original bronze valve guides. The 550 had a redesigned head and did not have as many problems with valve guides, although at least one European 550 owner did have to replace his valve guides because of excessive oil consumption and oil smoke. There is a possibility some late 456Ms were fitted with the sintered steel guides, but I have been unable to confirm one way or the other. That section of the 575M WSM was likely copied verbatim from the 550 WSM, error and all, when the WSM was written in late 2001. Brian Crall says good quality bronze valve guides work fine in the 456/456M (and F355, which had similar problems on some cars). Taz Terry Phillips Present: 575M 135171 Past: Dino 246 GT 02984, 365 GTB/4 14009, 308 GTS 25125 Every day I look around, and if nobody is shooting at me, it is a pretty good day. |
| | #14 |
Ferrari Life Posts: 859
I went through school on both cars. It would be far easier to list the things that are the same. The first 15 pages or so of my 575 school book is a list of major differences. It is a very long list. I suspect there are few interchangeable parts. The school notes also have an additional 10 or so pages on what I consider the ill concieved and poorly executed TPMS system. I have never seen so much space given nor attention paid to any other manufacturers TPMS system. It would be an accurate ststement to say they are different cars with similar body work. |
| | #15 |
Taz, thanks for the confirmation on the guides. Do you have any info about the material Ferrari used for the valves themselves? Curious if they're a steel alloy, SS, or something even more exotic like Ti or inconel? Since Ricambi's price per exhaust valve is around $140 each and intakes are $200, it would "seem" they might be a bit more exotic than a run of the mill steel alloy. Brian, thanks for your input; is there any chance you'd consider putting some of that school info in the public domain? Not any proprietary service info that you use to make a living - just technical descriptions. Some owners may not be that interested in the technical details of their cars, but a number of us certainly are. '99 550, Rosso Corsa / Nero, S/N:114654, Assy: 31836, Engine: 52084 High mileage, low compression, and missing on a few cylinders.....just like my cars. |
