Help: 35 hp are missing
Old 08-06-2009, 05:26 AM   #1
Ferrari Life Posts: 18
Default Help: 35 hp are missing
Hi guys,
this morning i was on the dyno with my 550 Maranello. The resultat are 545,4 Nm (couple) and (331,4 kw) 450,6 Ps (you must convert on hp). So my car is missing near 35 Ps. That's not a great result.
What can i do to recuperate this missing power? Somebody has an idea?
Thanks in advance,
SK7474 is offline   Reply With Quote
Old 08-06-2009, 08:24 AM   #2
I had the idea that perhaps the "RAM-AIR" in front hadn't received enough air from the fan on the dyno and so the power decreased.
Old 08-06-2009, 10:44 AM   #3
Ferrari Life Posts: 3,613
Many thngs can affect dyno results such as dirty air filters, worn tires, state of tune, incorrectly gapped spark plugs, grade of gasoline, etc.
I would not worry about such a small difference.
Old 08-06-2009, 11:48 AM   #4
Ferrari Life Posts: 3,922
So you have 450 HP instead of 485, it isn't really going to make that much difference to performance is it? My 1984 308 QV left the factory with only 240 HP, I doubt it's even got 200 horses now, but it doesn't stop me enjoying it and loving it.
Archie
archiegibbs is offline   Reply With Quote
Old 06-19-2010, 03:27 PM   #5
agp22's Avatar
Ferrari Life Posts: 364
Originally Posted by SK7474 View Post
Hi guys,
Thanks in advance,
To be absolutely sure of the available power, I would drive it at 325Kmh (as better described in the owner's manual) for a good while. If it gets there, and you can hold said speed for 1 hour, you should have all of your 485. You may want to use a GPS as your speedometer may read 340. And wear a helmet.
Now seriously, I understand that dyno runs can give you different readings every time you start rolling the rolls, and as better explained by Gcalo, various factors may influence the readings.
Personally, I wouldn't care.
agp22 is offline   Reply With Quote
