| | #21 | |
Ferrari Life Posts: 7,974
16M MP4 - 12C Bentley SS Conv / RR / AH 3000 / Camaro 69Z28 | |
| | #22 | |
| Owner Join Date: Sep 2010 Location: Pacific North West
Ferrari Life Posts: 1,911
polish again. There are some videos on YouTube.com where a guy polished a Jeep plastic rear window perfectly. If the window can be zipped out, that would make things way easier than what I had to do on my 360 Spyder. | |
| | #23 |
| Owner Join Date: Jun 2011 Location: UK. New Forest.
Ferrari Life Posts: 505
| It is a replaceable item but not cheap and doesn't zip in and out. I had mine changed under warranty, but would have been about £1200 I was told. Again I was told it is removed by way of electrical current applied to built in wires which melts the seam to remove and then the same to refit. In the UK Ferrari tech comes to the dealer to make the change.
Nuovo Rosso Formula 1 '16M' |
| | #24 | |
I think for the bumper alignment you are going to have to get the bumper off and look at what has happened and hidden! I know you are 300 miles from the dealer but is it not down to them to collect, fix and return? Sold as perfect and clearly not! Otherwise it will have to be a trusted body repair shop that can at least check what is the cause of the problem before you decide what to do. Nuovo Rosso Formula 1 '16M' | |
| | #25 | |
![]() Confirmed no prior accident damage - only other place could have been at the dealer after they sent me pictures. I will attach the picture I was given but it may be a bad angle and just overlooked by the prior owners and a factory error. 16M MP4 - 12C Bentley SS Conv / RR / AH 3000 / Camaro 69Z28 | |
| | #26 |
What might have happened is they removed the rear bumper to do an oil change, they did this for my 360 at RTGT, then when they put it back on, they didn't connect everything up correctly. I would have it removed, and see if it's just not fitted properly. Make them wear rubber gloves, and make sure the car is clean when you do it, to prevent scratches, and more work, i.e. buffing.
| | #27 | |
My guess is when they installed the radar or just poor fitment - either way will have it looked at when it arrives in Chicago Cubs territory - pretty sure they have never won a World Series in 103 years. I will be there drinking coffee like champagne in hopes they are my Ferrari service g-ds and of course bearing St Louis Cardinal World Series trinkets which may not be the best idea but it ill be funny as hell.Thanks for all the advice - next time I get off my arse first buy second 16M MP4 - 12C Bentley SS Conv / RR / AH 3000 / Camaro 69Z28 | |
