Ferrari Life Posts: 477
I've experienced doubt once or twice when recommending to replace headers due to failure and the consequences that follow not doing so. I've got a '98 355 with about 15k on the odometer in here getting a header replaced right now. I figured it was a good time to share why this is important to the car's health. I'd also like to use this as an example of what a waste of time it is to heat wrap and ceramic coat cheap metal. Some seem to think it's just as effective to use inexpensive low grade stainless or plain steel and then cover it up...WRONG! You'll see here that these headers are built with thin, low grade metal and all the fiberglass insulation and stainless jackets have done is trap enough heat to literally melt down the tubing until it collapses and burns through. The stock headers have a good design and make great power but unfortunately weren't made from materials capable of standing up under the conditions. For this car, the client opted for the less expensive rebuilt header replacements which I got from Ricambi. In a perfect world an upgraded header like Tubi, X-OST Maranello, Fabspeed or a custom header made from 321 would be used. |
Ferrari Life Posts: 1,418
Holy cow Josh, that had to get HOT. Are you sure there isn't something else going on besides thin metal?
I haven't run any Lambda or EGT tests yet, there wasn't much point with pipe failures like this. Once I get it back together and allow the ECU to re-adjust I'll check things out. Unfortunately this is a common failure for the 355's and in my experience it's an issue that seems to be a cause as opposed to being a result. Generally the pipes fail, the car runs excessively rich and breaks down the catalytic which gets sucked into the engine or the raw fuel washes out the rings and causes low compression. |
| Owner Join Date: Nov 2009 Location: Near Olney, MD
Ferrari Life Posts: 884
I've seen a lot of guys ruin headers by putting that heat tape on them. If you have to use it to protect a starter motor or something only use it where you need it and leave the rest open.
------------------------------ Life is Good!
Absolutely, guys don't realize that heat retention is a large part of the pipe's purpose and limitation. Header tape works well, so well that it holds more heat against the pipe that it is able to tolerate. The only way to actually improve the situation is to use heavier gauge and high quality metal, at least 304 stainless if not 321.
Ferrari Life Posts: 859
Unmitigated garbage. Ferrari knew it and as long as the cars got out of warranty they didn't care. They have redifined headers as a consumable as a defense. |
It's amazing just how poor quality the material for these really is. The quality of headers on modern German cars, which is tubular to mount the catalyst to is worlds beyond this. Far less expensive cars with far less tuned exhaust systems...won't ever decay like this.
| | #9 | |
| Owner Elite Member Join Date: Jul 2006 Location: MAR
Ferrari Life Posts: 693
What aftermarket headers do you recommend. I once saw a set of QV at Competizione, and was apaled by the quality of the reconstruction. I'd like to do Tubi, but I'd also like to find them for about half the price. Everything you have heard is true. | |
| | #10 |
The best options would be a set of Fabspeed headers made from 304 stainless for $3,000, wrapped in custom inconel heat shields which are about $1,200 or custom headers made in 321 which would be about $3,500 and for $1,200 you get the custom inconel heat shields. The first option gives you a product reasonably comparable to the Tubi for a few grand less, the second option give you a seriously upgraded product for still less than the Tubi/X-OST/OEM options. |
| | #11 | |
Really, really don't care for the hotrodder look myself, not on a Ferrari. Looks very out of place to me. I only install Tubi. I am also a IAC/PFA Senior Judge and am going to write a request for a concours rule change to accept aftermarket headers as long as they are a reasonable facsimle of OE. Tubi would pass that requirement. | |
| | #12 | |
| Owner Elite Member Join Date: Nov 2009 Location: Ellicott City, Maryland
Ferrari Life Posts: 407
current Ferraris: 1995 F355 Spider, 2000 360F1 Modena "If you can touch them, they are real". | |
| | #13 | |
| Owner Elite Member Join Date: Mar 2004 Location: Maryland
Ferrari Life Posts: 1,394
Current: 85' GTS QV "I don't sell cars, I sell engines. The cars I throw in for free since something has to hold the engine."
