Ferrari Life Posts: 477
"barcheta" was kind enough to entrust his 308QV with me for it's major service and Sanden A/C Compressor Upgrade, after some deliberation. With his permission I'm starting this thread with some photos to show an example of the workmanship I try to provide. Talk is cheap, and most mechanics tell a good story...I'll use a picture book. A text book 308 major is done with the engine in the car, anyone who has done this job knows that performing the valve adjustment on bank 5-8 let alone doing the camshaft timing procedure is not a pleasant experience. Since the cars are in fact getting older a basic "in n out" belt service is just a portion of what they should receive. Often the cars end up being delivered with just new parts and not a service IMO, sometimes you get half way into the job and find it's necessary to pull the motor and go through it thoroughly which compounds the estimate by quite a bit. To provide a better service and approach these cars in a more educated way I've developed my own standard procedure. I start by performing a cylinder leakage/compression test before anything else is taken apart. This prevents us from spending time and money on an engine with greater needs, it also allows the client to make a fully informed financial decision ie: stop or continue). The next step of course is to get the engine out of the car so everything can be evaluated and the drivetrain/engine bay can get degreased and returned back fresh. Once the engine is cleaned the covers all come off, get chemical cleaned then glass bead blasted for that "new" look. After everything has been evaluated and cleaned the valves get adjusted, cam timing measured/adjusted and reassembly begins. I'll update the thread in a couple days once the motor is all back together and in the car. |
Ferrari Life Posts: 737
Woot! Luv the look of fresh ally ![]() Josh, are you going to paint, or powder coat the covers? Did the 308 have one of those old York compressors, and is that why you & Jim are moving to the Sanden? '99 550, Rosso Corsa / Nero, S/N:114654, Assy: 31836, Engine: 52084 High mileage, low compression, and missing on a few cylinders.....just like my cars. |
Ferrari Life Posts: 5,042
This deserves to be a wiki, minus my post of course. Look very fwd to this thread. BTW: [*ahem*]...it's OK to pan the 'wall paper' into the shot better....this is a car site afterall. Guide to the Galaxy: Don't Panic Rik -- LAH ! Current: 1990 Mondial T Cabriolet : Red/Tan 1995 456 GT 2+2 : Roso Metalizzato [Fer 311/C] & Tan Last edited by Granucci; 08-25-2011 at 12:12 PM. |
John, the 308 came factory with plain aluminum covers so I'm going to leave them fresh and unpainted. The intake plenum/throttle body will be re-shot in Red Wrinkle as it was originally done as well.
Ferrari Life Posts: 3,255
Great idea for a thread. Look forward to the progress
| Owner Elite Member Join Date: Mar 2004 Location: Maryland
Ferrari Life Posts: 1,394
Those shiny parts look sweet! Yes everything in there was original including the York. I nursed the oem York along as much as I could to include pully bearing replacement and conversion over to 134A. When it worked right it blew plenty cold to keep me confortable but not to chill me out of the car. The end of the last driving season it started making noise and wouldn't blow cold despite having a fresh charge and leak test. My thought was it was time for a change. I really think the 308 engine is beautiful when it's clean and or polished. I intend to leave it that way. I will say I have been thoroughly impressed with the level of detail, options and insight Josh has provided so far. Current: 85' GTS QV "I don't sell cars, I sell engines. The cars I throw in for free since something has to hold the engine."
| | #7 | |
'99 550, Rosso Corsa / Nero, S/N:114654, Assy: 31836, Engine: 52084 High mileage, low compression, and missing on a few cylinders.....just like my cars. | |
Ferrari Life Posts: 3,586
Josh- Great thread. Always fun to watch the pros at work. Plus see the happy owner's reaction. Taz Terry Phillips |
| Owner Join Date: Nov 2006 Location: Arlington, VA
Ferrari Life Posts: 310
Dupe? Dear Josh, Always love the look of clean parts on cardboard on a garage floor. Best regards, Robert |
| | #10 | ||
| Lol, moving is a bit tricky at this point but I've always been game for an adventure...never did get to take you up on that offer for TexMex last trip... Quote:
Jim provided the parts to replace the shifter shaft seals, another reason I opted to pull the motor. While having the sump pans off a thorough inspection ensued. The result was some debris found in the oil pump pickup, which was easily cleaned out and re installed to fight another battle. You'll also note the Sanden compressor ready for install. I sourced this from Rock at RetroAir in Texas. He sells a complete upgrade kit for the 308's & soon 328's, Jim is confident his system is working well and just wanted the compressor so after a conversation Rock agreed to break up the kit for me. I'm looking forward to selling and installing some of the complete kits in the future. The second picture is just me bolting down one of the freshly cleaned up and sealed valve covers. I wanted to share this picture because you wrench savvy types will note that I'm tightening down the cover with a 1/4" torque wrench. Tightening down the covers evenly and with the appropriate torque is just as important to maintaining the seal as a clean surface and high quality silicone sealers in the correct quantity. | ||
| | #11 |
looking good!
| | #12 |
Ferrari Life Posts: 6,599
Damn Jim, two new cars, ferrari resto, what's next? waterfront property? Engine is looking sweet. can't wait to see the finished product!
| | #13 |
Waterfront property in severna park or crownsville would be nice! I cant wait to see it all together either Current: 85' GTS QV "I don't sell cars, I sell engines. The cars I throw in for free since something has to hold the engine."
| | #14 | |
| Owner Join Date: Sep 2009 Location: East Coast USA
Ferrari Life Posts: 1,908
Looking good Josh! 360 & TR Cars & Coffee at CITY DOCK ANNAPOLIS 9am-noon Every Sunday F-CHAT Exile now living the Ferrari Life. | |
| | #15 |
LOL, Jim is going to need some good investment properties after I'm done with this thing...good to know you're there to help out Al. ![]() Here's the next installment... After a mix up on the water pump rebuild kit I opted to go ahead and get Jim a brand new water pump (the price isn't bad). As you can see this after market pump uses a more robust metal impeller where the original pump uses a plastic impeller. This is what the engine looks like just about assembled with all of the new, bead blasted parts fitted. The next installment will be with all of the extraneous goods attached, including the refinished intake plenum and throttle body. |
| | #16 |
| | #17 |
your engine is not allowed to look better than mine.......... Everything you know is wrong Stop chatting and start living the ferrarilife! |
| | #18 |
It's OK Ed, I'm sure your engine looks pretty also. No need to feel self conscious, we're all friends here.
| | #19 |
Tsk, tsk Josh, you couldn't have thrown some black paint on that water pump pulley and crank dampner just for the photo shoot? They're the only eyesores up close to all that clean ally. Just joshing you '99 550, Rosso Corsa / Nero, S/N:114654, Assy: 31836, Engine: 52084 High mileage, low compression, and missing on a few cylinders.....just like my cars. |
| | #20 |
Black paint is extra, figured I would save that for next time . The water pump pulley is actually anodized not painted so I cleaned and left it. The crank pulley didn't want to come off the crank so I opted to just let it alone. I'm not a fan of spraying paint just for the sake of doing so, personally.Good eye though |
