Ferrari Life Posts: 12,774
I have always had a soft spot for Dino 246s and think I might have found one of interest. In the past when I have looked at them, fitting comfortably behind the wheel has always been an issue (I am 6'2"). I did not want to buy an original car and then start to modify the cabin by remounting the seats and rails to make it comfortable. However one is coming up for sale that has been raced, and then restored to road spec. Hence it has already had the interior modified. What are the key things I should look for before buying? Boxer Current: F40, F50, 612, 430 Scuderia Past: 360 Modena, 360 Challenge, 550, 575, 365BB, 512BB, 456 GT, F355 GTS, 365 GTB/4 Daytona, 308 GTB |
| | #2 | |
Ferrari Life Posts: 3,541
Name: Jimmy Chen Shiba
Key things to consider are basically the same for all. Looks like this car is highly modified. It would be great if the current owner possess the original parts. Very often, people are not aware of the fact that parts are not correct, such as bumpers, steering wheel, etc. It would be ideal if you can test drive this car, Boxer. Let me attach some pics of another modified Dino that I saw few years ago. If I can be of any help, Boxer, and if I can answer, I am more than willing. By the way, what are the facts, like year model, model type (L,M, or E)., etc. ? Good luck and keep us updated. w/ smiles Jimmy | |
Jimmy, Many thanks. I will post more information when I have it. TO the best of my knowledge, the car has been restored/returned completely back to road spec.
| Owner Join Date: Jan 2010
Ferrari Life Posts: 311
Not too different than examining the mechanicals as in other period cars, so I don't have many special things to suggest but do look at these: - check the alternator fuse box on the engine firewall, these are rare as hens teeth - lighting/electrical systems can develop corrosion, check these - Alternator appears clean (is located where oil can drip on it) - the 2 cross tank fuel hoses that span 6 inches from each fuel tank are often neglected, inspect these for fatigue, drying, and micro-cracks The standard typical mechanical inspection applies so don't forget to do due diligence of these: - Leak down and compression test - braking and driving straight - hoses and 3 coolant pipes in good condition The Dino can be quite reliable and does benefit if an aftermarket ignition box is used, so that should not be a deterrent. Last edited by SCM246; 01-17-2010 at 05:11 PM. |
Ferrari Life Posts: 3,255
Boxer, Nick Cartwrights specialise in restoring Dino's if it was within reach they might be worth contacting for a PPI if you were planning to buy? Barry Ferrari's: 360 Modena F1, 308 GT4 Other Italians: Ducati 916, Ducati 848 DD's: RR Sport, BMW 645ci, BMW 1200GS Adv. |
| Owner Elite Member Join Date: Aug 2007 Location: Amsterdam
Ferrari Life Posts: 638
When I got my Dino 246gt I was told to beware of 3 main weaknesses: 1. rust 2. electrical 3. cam lobe wear-these motors love to be revved and if not taken above 5000rpm regularly, develope rapid wear of the cams. Mine was rhd which helped accomodate my 6 4" frame better than lhd as the gear lever is situated on the lhs of the transmission tunnel whether lhd or rhd. Thus with rhd I had more knee room. In lhd Dino's my splayed right knee obstructed access to the gear lever. The rhd Dino was one of the few instances where rhd was preferable to lhd for me. Happy hunting, the Dino is a magnificent Ferrari. |
| | #7 | |
| | #8 | |
Boxer Current: F40, F50, 612, 430 Scuderia Past: 360 Modena, 360 Challenge, 550, 575, 365BB, 512BB, 456 GT, F355 GTS, 365 GTB/4 Daytona, 308 GTB | |
| The one I am looking at has been in Nick Cartwrights care for the last decade.
| | #10 |
| Owner Join Date: Apr 2006 Location: France
Ferrari Life Posts: 159
You can look for rust under the doors once you open them . There can be an oil drip from the chain tensionner onto the alternator (which make the alternator not giving enought/any Amperes) If you Test drive the car ,check (when the gearbox is hot) if the second gear synchro is good and doesn't make bad noise ... (it's often the one which loose first) The steering rack can often have play also. It is NLA new at Ferrari Maranello but there are shops that reconditione the old ones. Maybe the seat of the first serie 246 gt can go further back (than others series) for tall people ,because the headrest are not attached to the seats.But 246 gt 1st series are rare. The Dinos are fantastic cars !! (especially with a little more HP) |
| | #11 |
I missed out on the Cartwright cared for Dino. Search goes on.
