Ferrari Life Posts: 1
We generally refer to them as seat bottoms, but the manual references them as pillows. How do I get them out? The manual shows a nut holding the frame to a stud on the front near the center arm rest. Removed the nut and the pillow will not budge, still something grabbing at the front in-board. Can get the rear lifted up, but it will not slide or lift at the front. Any suggestions? Thanks a lot. |
| Owner Join Date: Mar 2002
Ferrari Life Posts: 286
Buck, I don't have a Mondial but it seems to me that once you take the bolt out you have to pull the seat away from the frame where it is locked in place with its own spring clip. You have to maneuver the cushion around and pull upward and outward to release the clip from the frame. Let us know what the result is. Magoo
Ferrari Life Posts: 5
There are two nuts at the front left/right that you will need to remove. They are partially hidden by the pillow overhang. Can't remember the size but you will need an extention to get them off and a hell of a lot of patience to put them back on.
