| Owner Join Date: Jul 2005 Location: San Anselmo, California
Ferrari Life Posts: 13
Can anyone tell me where the oil pressure sending unit is located on a 3.2 Mondial?
| Owner Elite Member Join Date: Jun 2002 Location: USA & Singapore
Ferrari Life Posts: 5,402
Well, I can tell you where it is on a 308, maybe it is the same on your 3.2 liter. If you stand on the driver's side of the engine, look at the oil filter, now look down at the oil filter mounting housing. You will see a fairly decent sized fitting with a wire coming out of it. That's not it. That is the oil pressure switch that runs the light to tell you when you have NO oil pressure. Now lean over the oil filter and look at the oil filter base (on the intake manifold side), you will see a smaller fitting with a wire attached to it. That's the oil pressure sending unit that powers the gauge. You do have to remove the oil filter base to change the sending unit (at least on a 308). Hope that helps! Capt. Pete '79 308 GTS, '82 Jeep CJ7 Jamboree "Time is what prevents everything from happening all at once." |
Here you go, should be worth 1,000 words. Is this the same as yours?
| Administrator Elite Member Join Date: Nov 2001 Location: San Francisco
Ferrari Life Posts: 6,182
Pete, I like the date marking on the oil filter. Clever thinking. |
| | #5 | |
I do that on all my cars (and even my lawn tractor). When you've got 5 cars it's hard to remember exactly when you changed the oil in what. As you can see, I changed the oil in the Ferrari quite recently. You'd like my car trailer, I have the part number for the wheel bearings and wheel seals stenciled on the frame. Capt. Pete '79 308 GTS, '82 Jeep CJ7 Jamboree "Time is what prevents everything from happening all at once." | |
Thanks guys. That was the spot |
