slow down 1/4 warning!
Old 01-22-2010, 03:13 PM   #1
Ferrari Life Posts: 23
Default slow down 1/4 warning!
Hi,
I am a new 1989 mondial t owner, 16K miles.
The "slow down 1/4" warning light sometimes comes on after driving the car for appx. 30 minutes. Oil pressure, water and temperature gages are all fine and the car is running fine. The car had not been used for several years before Ferrari had done a major engine out service a few months ago.
Would there would be harm in running the car with the warning light on?
Thanks for any advice.
Rob
RoPo54 is offline   Reply With Quote
Old 02-08-2010, 12:10 PM   #2
Ferrari Life Posts: 4,994
Originally Posted by RoPo54 View Post
Hi,
Rob
can't believe this has been missed: 348 engine warn light on.
You should take it back to Ferrari and have them read the code. Sometimes as it has not been run the sensors need to get worked out.
Since pres and temps are ok, I am not thinking the worse, but you should have it looked into.
Old 02-08-2010, 12:31 PM   #3
Saint Bastage's Avatar
Ferrari Life Posts: 1,674
I did not respond as I am not specifically familiar with the Mondial. I did however just notice its the Mondal T. If I'm not mistaken, thats the same as a 348 right? If so, the slow down warnings are almost always a result of catalizer issue's. They are either to hot or being misrepresented by the cat ECU. The cat ECU is the normal problem. If its just the ECU, driving with the light on is not much of an issue. Best way to tell is to swap ECU's side to side and see if the Slow Down 1/4 becomes Slow down 5/8. If it does, thats the problem. ECU's are fairly expensive but Daniel at Ricambi can set you up. If you've noticed the issue when the car has been exposed to moisture, it may be a simple seal issue. Check the 348 section for ECU sealing. I put a photo essay in there for fixing it.
Good luck
Lane
Lane
348ts SS #64, Nero on Nero
Old 02-08-2010, 03:59 PM   #4
Magnum6464's Avatar
Ferrari Life Posts: 1,687
Bastage,
Yes, Mondial T, same identical engine and yes your solution is the same.
Could also be a bad plug, but if it runs great, this should not be an issue.
Mario
1990 348 TS (87284)
Magnum6464 is offline   Reply With Quote
Old 02-08-2010, 05:48 PM   #5
Ferrari Life Posts: 6,572
Time for the old "italian tune up".
Old 02-08-2010, 07:09 PM   #6
A serious caution for the "Italian tune up". A friend has a destroyed a 348 engine due to a cat failure. I doubt thats the problem here but then again, I can't see it, feel it, or taste it across the Inet. Also, if the ECU is the problem, forcing the issue will only get you into limp mode.
I'd love to hear more about the problem and a bit more troubleshooting before deciding anything for sure.
Lane
Old 02-09-2010, 04:16 PM   #7
Magnum6464's Avatar
Like you said, first step, swap ECU frm 1-4 to 5-8 then work from there.
Mario
1990 348 TS (87284)
Old 02-10-2010, 05:38 PM   #8
I have continued to run the car without the light reappearing but one other time right before calling it a day after driving it over the weekend for several hours. It has not reappeared again. Taking it in to the mechanic to have a look at next week. The couple of times the light has appeared it has been after 45 min - 1.5 hours of driving. It has gone off upon a restart and the engine runs just fine.
Rob
Old 02-11-2010, 11:59 AM   #9
BTW, my car does have a chip upgrade. (Thanks for your help)
Rob
Old 03-10-2010, 06:18 PM   #10
Ferrari Life Posts: 9
chipped could throw code. the ecu rolls around i forget the intervals and if the light is going off then the ecu is not seeing it agian as it rolls. (non issue) you can blink the codes yourself from the ecu... they apear on the dash like morse code. i rarely trust the code on these motronics. Do you like the chips... they remap everything up top and thats not too good for regular "ferrari" driving. what intake and exhaust on the car?
twestby is offline   Reply With Quote
Old 03-12-2010, 03:39 AM   #11
Tried swapping the O2 sensors and the engine started stalling out and running very rough and the Cats got very hot. Switched back and the car ran fine again. The slow down sensor still may come on intermittently but onlay after about driving for 45 minutes and then will go off in a few minutes, without any manisfestation of engine running poorly while the light is on. Will take it in for some more testing next week.
Old 03-12-2010, 10:33 AM   #12
How clean are your connectors? Ask Dave Helms on this too.
Old 03-23-2011, 12:58 PM   #13
lightning's Avatar
Ferrari Life Posts: 22
Default Warning lights
These "slow down 1-4 and 5-8" warning lights, should they come on briefly when you turn on the ignition before you start the engine, or do they only ever appear when there is a fault condition?
Mine never appear, but somebody told me they should flash briefly when you turn the ignition on.
lightning is offline   Reply With Quote
Old 03-23-2011, 03:14 PM   #14
Your lights will cycle on startup. That is to be expected. I believe the manual even discuss such, but if you are getting zero lights, I'd have it looked at.
So, if those lights are not showing [refer to manual for what should show on startup as part of the cycle] what else is not showing?
Old 03-26-2011, 10:04 PM   #15
Ferrari Life Posts: 16
[QUOTE=RoPo54;109356]Hi,
You might try to re-initialize your ecus. This sometimes can cure a world of ills and is easy to do. It worked for me.
Reinitializing/Resetting A/F ECU's: When your engine is cold, disconnect your battery for 35 seconds (this can be done by turning your battery disconnect switch). Hook it back up, start your car, and let your car idle for 10 minutes (or until at least one radiator cooling fan kicks on). Do not touch the accelerator (before or during this 10 minute period). Do not self-activate any electronics during this time. Your ECU's are now "re-initialized."
gidleigh is offline   Reply With Quote
Old 03-27-2011, 11:42 PM   #16
lightning's Avatar
Default Slow down lights
Thanks for the advice.
However I'm almost certain that my "slow down" and "check engine" lights have been disconnected.
I can't imagine where the connections might have been broken. The bulbs are still in their holders, if I could get the instrument shroud off I could look at the wiring behind the bulbs, but I can't work out how it comes off.
Having said that the car runs well. It's not so good for the first half mile (engine tends to shunt and poor low RPM pickup) but after that it performs well, no misfires or lack of power and idle speed just over 1,000rpm.
I think the ECU is (are) probably in default/check engine mode though, hence the poor choke operation, as default mode is "hot engine".
It needs looking at really. It's going in for annual service next month so they will hook it up to the ECU reader and may get some clues as to what is going on.
Old 04-22-2011, 08:52 PM   #17
ferraricyprus's Avatar
Ferrari Life Posts: 35
In '89 you could have either 2.5 or 2.7 motronic. The 2.5 variant has no plug for a diagnostic unit. Fault tracing was done through a device known as a break-out box. If I were you I'd open the luggage compartment and pull the carpet off the firewall (release the three half-turn screws and it will come away easily) and look behind it. To your right you will see a silver metal box; this is your engine motronic. If there is a plug hanging out of the harness around 5 inches from this box it's a 2.7. Look for two small black boxes either side of the panel, these are the cat e.c.u's which send signals to the motronic unit which then controls your dash lights. These may have been disconnected, either due to a system fault on the electrical system, a failed/poor cat or if the cats have been bypassed or updated
ferraricyprus is offline   Reply With Quote
