warm starting problem 3.2 mondial
Old 11-04-2009, 04:46 PM   #1
Ferrari Life Posts: 6
Default warm starting problem 3.2 mondial
My 3.2 mondial starts fine when the engine is cold, but after warm up, if it sits for a while. when I start it seems like it runs on two/three/four cylinders,and then it gradually clears up. I also noticed it has an intermittent skip at idle. Has anybody experienced anything like it? or have any suggestion on what could be causing this.
vict is offline   Reply With Quote
Old 11-04-2009, 05:08 PM   #2
Saint Bastage's Avatar
Ferrari Life Posts: 1,674
sounds like a fuel supply issue. I'm not versed in the 3.2 but thats where I'd start.
Lane
348ts SS #64, Nero on Nero
Old 06-04-2010, 11:54 PM   #3
Default warm starting problem on 308 QV
Hello vict. I have a 1984 308 QV, it works fine, but it has the same problem when it's warm. I changed the ignition wire, the plug and the spark plug. Maybe it is due to injectors or fuel accumulator. Do you solve the problem ??
toni is offline   Reply With Quote
Old 06-05-2010, 09:59 AM   #4
Ferrari Life Posts: 476
Do a fuel pressure check while cranking when hot. When the car is cold the cold start injectors make sure it's fired up...when it's hot they're not functional. It appears to be a fault in the primary fuel system, could be the fuel pump is getting weak.
Ferrari Life » Ferrari Forum » Ferrari Owners » 2+2: 365, 400, 412, Mondial » warm starting problem 3.2 mondial
