Ferrari Life Posts: 5
my auto adjust supension light has come on and wont set,... ive checked each shocker to see if anything is seized , all 4 top adjusters work and the auto test goes through a cycle when first turned on , any ideas whats wrong
Ferrari Life Posts: 4,994
the light on, is typical indication of a bad sensor or actuator. I'd have them checked again. It may seem to work correctly, however, there might be a slight problem with the worn wire connectors, or the motor or even the gear. Might want to replace fuses, and the IIRC, relay, by swapping that out. The switch is a bugger to get into, but, might want to consider that.....my lights would always go on when a motor or such was bad. rik Guide to the Galaxy: Don't Panic Rik -- LAH ! Current: 1990 Mondial T Cabriolet : Red/Tan 1995 456 GT 2+2 : Roso Metalizzato [Fer 311/C] & Tan |
SIDE NOTE: Ferrari's manner to handle bad actuators for some of these earlier cars was IF the motor, sensor, or such went bad to LOCK all the suspensions into the HARD position and put the light on. The light will not go away till actuator[s] fixed, or wiring fixed, or such. NOT A BIG DEAL but know also that the car will be in the HARD setting until fixed too. Guide to the Galaxy: Don't Panic Rik -- LAH ! Current: 1990 Mondial T Cabriolet : Red/Tan 1995 456 GT 2+2 : Roso Metalizzato [Fer 311/C] & Tan |
