| Owner Join Date: Mar 2009 Location: Ironbridge Shropshire
Ferrari Life Posts: 27
Hi all, the metric tyres on my mondial are 220 55 390 and finding them can be a bit of nightmare, I need two for the back and can find some very reasonably priced 220 65 390. I know these a little higher (if thats the right term) but it seems to me like that would fit perfectly. Has anyone got any thoughts on this? Any advice greatly appreciated. thanks Darren |
| | #2 | |
Ferrari Life Posts: 12,730
http://www.longstonetyres.co.uk/index.php Boxer Current: F40, F50, 612, 430 Scuderia Past: 360 Modena, 360 Challenge, 550, 575, 365BB, 512BB, 456 GT, F355 GTS, 365 GTB/4 Daytona, 308 GTB | |
| Owner Join Date: Mar 2007 Location: HK
Ferrari Life Posts: 11
Check your tire dimensions. I think the correct numbers are 240/55 VR 390, all round. The original tyre was a Michelin TRX. |
| +1, just checked a copy of the owners manual. Only difference is in recommended tire pressures. Fronts are psi 33 and rear psi 35.
So it is :-) TRX tires are quite noisy compared to modern tires, and obviously of older design, so less "good" than a good modern tire (Michelin, Yokohama etc) You may consider updating to Superformance Replica wheels and modern 225/50 R 16 that gives the same width on the road and circumference (±2%) than the old setup, so the gearing/speedo remain correct. |
| | #6 | |
| Owner Join Date: Jul 2005 Location: Manchester UK
Ferrari Life Posts: 271
http://www.camskill.co.uk/products.p...298&mode=print | |
Ferrari Life Posts: 4,994
funny: The T is getting a new set of shoes this week, but my sizes are different than yours and diff front vs rear. Just put on a set of Nitto's for the 456 and they are performing very well...VERY nice mfgr....might check them out..but for the Mondials, unfortunately no go. Guide to the Galaxy: Don't Panic Rik -- LAH ! Current: 1990 Mondial T Cabriolet : Red/Tan 1995 456 GT 2+2 : Roso Metalizzato [Fer 311/C] & Tan |
It does seem odd, the car sticker in the window says 240 rear and 220 front. Eurospares says 220 all round and mine has 220 all round. I have found some nice part worns but they 230 55 390 does anyone know if they will be ok? I gather if the car can have 220 and 240 then I guess the one between will also be ok. Or if I do go for the 220 option will a 65 be ok. This is only height..am I right? Dont know much about tyres to be honest. cheers |
Darren; Dealer might have stuck on different set for rear. Actually, in my manual the tires a larger in rear Guide to the Galaxy: Don't Panic Rik -- LAH ! Current: 1990 Mondial T Cabriolet : Red/Tan 1995 456 GT 2+2 : Roso Metalizzato [Fer 311/C] & Tan |
| | #10 |
| Does the t still run metric tires ?
| | #11 |
| well, I'm in US...don't use the nomenclature seen above. So, bascially saying no.
| | #12 |
| Just checked the owners manuals. They moved back to "normal" tire sizes for the Mondial t. Also the rears are larger than the fronts: 205/55 ZR16 Front and 225/55 ZR 16 Rear.
| | #13 |
The 8 and QV had metric wheels of same dimensions all round. The 3.2 had metric or imperial wheels, depending on the market. The t only had imperial wheels. The 3.2 and t also had narrower wheels at the front than at the rear. The wheel alignment for same-size vs. front/rear different size is NOT the same. So, should you convert an 8 or QV to different size front/rear, you ought to redo your alignment accordingly to benefit from the change fully. |
| | #14 |
thanks guys. I am going to stick 230 55 vr390's on the back because I can get these much cheaper as they were a bmw size in the 80's I believe. the 55's seem a bit more rare and command the higher prices. If the car should have 240's on the rear then I guess Im not far wrong with a 230. Im sure it will look at bit more meatier from the back also compared to the 220's currently on there. I downloaded the tire calculator for my iphone, its a great bit of kit for 59p. |
| | #15 |
| Owner Elite Member Join Date: Apr 2006 Location: Northern Ireland
Ferrari Life Posts: 567
The Mondial 8 I used to own had 240's all round and the 308 is 220's all round.
"When I was a boy, I had a dream. It now sits in my garage". www.maranellohouse.com Lifetime Honorary President NI Italian Motor Club www.niimc.net |
| | #16 |
Had the tires put on today, 2 part worn 230 55 vr390 over the moon with them. They cost me 75 for both and had them balanced and fit for £20. Think I have saved myself a lot money. I do love eBay.
| | #17 | |
those are new tires, right? did you check the side wall for mfgr date. Guide to the Galaxy: Don't Panic Rik -- LAH ! Current: 1990 Mondial T Cabriolet : Red/Tan 1995 456 GT 2+2 : Roso Metalizzato [Fer 311/C] & Tan | |
| | #18 |
Tire age is critical. Over 8 years is a no go in my book.
| | #19 |
Ferrari Life Posts: 3,613
Tire age is very critical as is proper sizing. Get the true OEM size and then use this calculator to know for sure. Don't guess: http://www.miata.net/garage/tirecalc.html |
